on my CYT4BF device i have an Autosar Application running only on CM7 core. For Bootcore CM0+ there is no application available. How do i manage the correct startup and "running" behaviour for the CM0+ core?
Martin
TRAVEO™ T2G
- Please go through the first question in the following document to check if your system call is working fine - https://community.infineon.com/t5/Knowledge-Base-Articles/Traveo-II-Automotive-Body-Controller-FAQ-B...
- You can also go through '37. Nonvolatile Memory Programming' chapter in the Architecture TRM to learn more about system calls.
- As already mentioned in my previous response, the following application note has the detailed startup code for CM0+ core - https://www.infineon.com/dgdl/Infineon-AN220118_GETTING_STARTED_WITH_TRAVEO_II_FAMILY_MCUS-Applicati...
- You can also go through the actual startup file present in the SDL to understand the steps better. You can download the latest version of the SDL from here - https://www.infineon.com/cms/en/product/microcontroller/32-bit-traveo-t2g-arm-cortex-microcontroller...
- Since this is an MCAL related question, I request you to contact your local sales representative or FAE to get more support.
Regards.
Hi Martin,
You can find the CPU startup sequence for CYT4B in section 3.2.3 of the following application note - https://www.infineon.com/dgdl/Infineon-AN220118_GETTING_STARTED_WITH_TRAVEO_II_FAMILY_MCUS-Applicati...
Let me know if this answers your question.
Regards.
In my autosar application for CM7 the ECU is hanging at function: Fls_InvokeFMAPI
The Elektrobit support answered to this issue:
"Fls driver can be run from CM7 itself. Actual programming is initiated through system calls which can be executed only from CM0+. Fls driver uses IPC to invoke the system calls in CM0+.
So whenever you use Fls in the application, core CM0+ needs to run because FLS will use system calls from that core.
If CM0+ is not started and runing, the Fls driver hangs in Fls_InvokeFMAPI same as customer reported. "
My conclusion is that the CM7 uses IPC messages for invoking system calls on CM0+. The root cause of this issue potentially is on CM0+ core. How can i check if CM0+ is running correctly?
Regards.
