CANFDx_CHx_ECR.REC & TEC - reset
tish_4721196
For Address 0x40520040 Register TRM says ECR. REC and TEC are read only for software. I want to understand how do ECR.REC
Nambi
50 likes received 5 likes given 100 solutions authored
Yes. All these listed reset sources will reset the register.
Nambi
REC"Receive Error Counter" and TEC"Transmit Error Counter" are read-only for software. They are updated by the internal CAN-FD hardware IP.
I understand from reading Register TRM that its only read only for software and Read/write by hardware.
What I want to know is what condition cause Hardware to write register to default?
Nambi
All reset sources will reset this register to default value.
Please confirm that any one of below resets will cause REC & TEC to reset to default value.
Thank you
Nambi
