Hi All,
For writing the data in workflash from CM4 core ,do I have to consider any interrupt settings?
Since I am using the CM0+ core just to jump to CM4 core.
TRAVEO™ T2G
- Work flash access
Hi Venkatesh,
Any write to work flash happens through system calls irrespective of the cores and the user software is responsible for correctly setting up CM0+ IRQ0 and IRQ1 interrupts for system call
management.
I request you to refer the application note attached for detailed information.
Thank you.
Hi Venkatesh,
management.
Thank you.
