ZhouFeng
First question asked Welcome!
I used Microcontroller CYT2B7 80-LQFP
1st, I use only SAR2 ADC group, ADC channel from 0 to 7 were used channel 7 is the last channel .
2nd, I get ADC convert result by copy PASS0_SAR2_CHx_RESULT register value not by interrupt and DMA.
3rd, I get ADC convert result timing is check register PASS_SAR_CH7_INTR_MASK bit0 GRP_DONE_MASK [0:0] set to 0x1.
My question is if we only check register PASS_SAR_CH7_INTR_MASK bit0 GRP_DONE_MASK [0:0] set to 0x1, Can I consider no ADC group and Channel overflow happened and don't need both check  GRP_OVERFLOW_MASK[2:2] and CH_OVERFLOW_MASK[10:10]. Is the GRP_DONE_MASK and GRP_OVERFLOW_MASK are mutual exclusion.
Thank you to the answer.
abhikul
50 sign-ins 10 solutions authored 25 replies posted
Hello @ZhouFeng
Could you please elaborate all your three statements mentioned in your query more clearly?
Also please state what exactly your query is all about.
Thanks & Regards
Abhishek Kulkarni
