Aug 12, 2021
11:54 PM
Aug 12, 2021
11:54 PM
I'm using flash driver to erase sector 0x100B 8000 of MCU CYT2BL8C, the flash driver runs from RAM 0x0800 2000.
After an IPC NOTIFY event written to IPC1 register, on M0+ site, a hard fault is immediately detected.
I'm not clear the reason causing this situation. Does this have something to do with the protection context(PC)? How could I find in which PC is the current code executing?
Does anyone have any ideas about this case?
thank you in advance.
Zhimin
- flash erase
12:25 AM
Aug 26, 2021
12:25 AM
Hi Ashish,
I think this issue is related to a "code in RAM" problem. After I remap the code, that is executing in CMO during flash operation, to RAM, the flash operation issue is solved.
thank you for your info.
BR,
Zhimin
