Hello.
I would need the evaluation board and GUI SW for the TLE4999C8. I did not found any information on it on TLE4999C's webpage...
(I already have PGSISI-2 and 3 boxes. I used it for TLE4997 and TLE4999i3 ).
Thank you.
Hello @JTEKTGui ,
Can you please confirm the version of the board you are using? If the board is version 4.1, it will support the PSI5 and the SPC (TLE4999C8).
In case if you need a new board because of the older version, and also for software update for the C8 SPC version, we would suggest you to contact your Infineon sales person.
Honey
Hello @JTEKTGui ,
Honey
