Community will be in read-only mode on 25th Sep for 10 hours. Click here for more details
FilembarEliJeev
I've had terrible experiences with the reed switches. They malfunction regularly. Has anyone used Hall Effect transistor sensors? I'm thinking of using those instead going date forward.
PalY
250 sign-ins 25 likes received 50 solutions authored
Hi @FilembarEliJeev ,
Please check out our Omnipolar Hall Switch TLE4931, for use in low-power devices. This should be applicable for switching in presence of a magnet.
Thanks and regards,
Yashraj
PalY
Here is the link of all the Hall switches from Infineon, where you could go through the product's page.
If you could  share the application for which you want to use the Hall switch, we could suggest a suitable product.
Thanks and regards,
Yashraj
FilembarEliJeev
I use reed switches in about a dozen different escape room puzzles. Most of the time, without a hitch. But every once in a while they get "stuck". I can sometimes fix this by putting them in a stronger magnetic field, but ultimately they'll end up sticking again. About 1 in 20 units have this "feature". And it always happens after the puzzle has been in use without an issue for a few weeks.
PalY
Thanks and regards,
Yashraj
