In WICED 6.2.1 I could see wiced_hal_i2c_select_pads(scl_i2c, sda_i2c) only in the API for 20735_B1, but not for 20719_B1?
So what is the solution for 20719?
You can configure i2c pins in /20719-B1_Bluetooth/platforms/CYW920719Q40EVB_01/wiced_platform_pin_config.c as mentioned in comments in /20719-B1_Bluetooth/include/20719/hal/wiced_hal_i2c.h.
CYW20719 has dedicated I2C pins. Whether as, All GPIOs are supermux in CYW20735. All GPIOs can be programmed for any alternative functions. For example, key scan, SPI, I2C, IR_TX, quadrature, peripheral UART, ADC, etc. Therefore wiced_hal_i2c_select_pads() is given to select the pins.
Thanks for the answer but the spec sheet for 20719 (Document Number: 002-14815 Rev. *D) claims opposite: Table6 GPIO Supermux Input Functions on page21 says SCL, SDA are elgible for Supermux-ing on any eligible GPIO pin as per Table 5. Not only on dedicate 16,17
Which one is true/false - your last posting or spec sheet?
