wiced_bt_*_disconnect* with reason parameter?
StN__1917156
Level 4
Level 4
25 replies posted 10 replies posted 5 replies posted
Is there any hidden disconnect function that accept and a disconnection reason as parameter?
all the wiced fuctions wiced_bt_gatt_disconnect , wiced_bt_l2cap_disconnect_req,,wiced_bt_l2cap_le_disconnect_req
accept only single connection_id parameter,
but the other BT stack providers have functions like sd_ble_gap_disconnect(conn_handle, hci_status_code ) where and hci_status_code could be specidied
I have regular random  errors like 8109 / 61 that can see on the terminal program, but they are never reported to the Android client -
just got the general error 133 after 20 seconds (what is the hardcoded supervision timeout in Android), so I'm trying somehow to "report" and identify/ distinguish those errors on the client side and preferably ASAP (not after 20 sec)
SheetalJ
First comment on KBA 750 replies posted 500 likes received
Unfortunately, we do not have have any function or API with disconnection reason as parameter. Our function return the success/failure reason as mentioned in structure wiced_bt_gatt_status_t (wiced_bt_gatt.h).
SheetalJ
