wiced bluetooth classic reconnect
MaVo_3395126
10 sign-ins 5 sign-ins First reply posted
I have an A2DP device (cyw20706) that does not always reconnect to ios when disconnected.  Is there a way to attempt a reconnect from the device?
Owen_Zhang123
5 questions asked 500 solutions authored 250 sign-ins
Are your trying to reconnect the A2DP profile as a sink device?
You may use the API wiced_result_t wiced_bt_a2dp_sink_connect(wiced_bt_device_address_t bd_address).
Or you can also refer to the function a2dp_app_hci_control_connect() in headset demo.
Owen_Zhang123
Which SDK are you using? MTB or WICED?
MaVo_3395126
Owen_Zhang123
