unable to program CYBT-423028-02(Module) using USB-UART bridge
ns_4270701
10 replies posted 10 questions asked 5 replies posted
Hello Sir/Madam,
   We have designed our own customized PCB board using CYBT-423028-02 module. A screenshot of a schematic is attached here.
Development environment:
Windows 8.1 pro
Platform: CYBT-423028-02 (Module)
IDE: Wiced Studio 6.2.1
Hardware: Customized hardware board using CYBT-423028-02 module
Also followed the steps suggested in this link: WICED Studio: Platform Files for CYBT-423028-EVAL - KBA223637
We are facing to program a CYBT-423028-02 module using USB-UART bridge.
Please note we have followed the hardware setup and connection as suggested in below link.
Programming an EZ-BT WICED Module – KBA223428
And tried to load an application to the module, got the output in a console as attached here.
Owen_Zhang123
5 questions asked 500 solutions authored 250 sign-ins
Did you try to program in the recover mode:
1. Pull the UART_CTS to GND
2. Power cycle the device
3. Release the UART_CTS pin
Then program it again.
You may also use the module programmer: WICED Module Programmer User Guide – KBA225060
