Jeff_Huang
5 questions asked Welcome! First question asked
the end customer have designed a module product using CYW20706+Serial Flash.
when the serial Flash already be mounted on boards with CYW20706,If new software needs to be upgraded into the serial Flash for lots of modules..
in this case ,Is there a program tool for 20706 module mass production?For example, the tool can programe 8 modules at the same time
thanks.
GyanC_36
250 replies posted 100 replies posted 50 replies posted
    There is no tool available for programming the CYW20706 multiple devices concurrently.
Gyan
GyanC_36
Gyan
Jeff_Huang
Hi,Gyan,
now WICED and OTA upgraded the software,the end customer thinks it's slow for mass production.
how to improve the efficiency for programming lots of modules?Do you have any suggestions?
thanks for your support.
