mawu_4270096
5 sign-ins First like received First like given
Hi :
   today I meet a strange question that my CYW920735Q6EVB-01 board can't print debug message. I have verified the Uart hardware is good, and the Baud rate is correct.
I use the SDK version is 6.4.61
I use the  WICED_BT_TRACE("XXXXXXXXXXXXXX", )  to  print the debug message , but it can't print the message
but I can use the  HCI UART to download firmware
thanks!
mandy
DheerajPK_41
Hi mawu_4270096,
Could you please add "C_FLAGS += -DWICED_BT_TRACE_ENABLE" in the makefile.mk of the application and try again. Please do clean and build.
Also if needed please enable  "MESH_MODELS_DEBUG := 1" from the makefile.mk so that you can get model debug prints.
-Dheeraj
DheerajPK_41
Hi mawu_4270096,
-Dheeraj
