hi madem/sir
here i need some solutions for for below questions,
1) there is any API for rebooting or restarting the cybt-343026 module.
2) some times bluetooth is not connecting or pairing properly (mainly when i am changing bluetooth name).
3) if module receiving 100 bytes of data (0x20/spaces) from PUART RX again it is returning the same data to the PUART TX.
thank you.
Hi HaGo_4718696,
1-A. There is no API to reboot or restart the module. You will have to use the hardware reset button.
2-A. Which example are you working on? WICED version? Please provide more details.
3-A. Is this only UART transfer or SPP data transfer? Please provide more details about the app and implementation.
Hi HaGo_4718696,
