hi Cypress:
if cyw20706 need to set the i2s to slave mode? if A2DP sink is mean ,the cyw20706 is in slave mode?? so the host should set in mast mode fo i2s?
Hi DaZh_2976111 ,
Depending upon your application and codec requirements , you can put the 20706 in I2S master or slave mode in the application.
For example, refer to example in WICED SDK - /20706-A2_Bluetooth/apps/snip/bt/a2dp_sink
Refer event WICED_BT_A2DP_SINK_CODEC_CONFIG_EVT .
route_config.route = AUDIO_ROUTE_I2S;
route_config.is_master = WICED_TRUE; // will set as I2S master
Other references :
PCM/I2S Clock Setting in CYW20706 for Audio Applications - KBA228409
Anjana
Hi DaZh_2976111 ,
Other references :
Anjana
