Hi all:
now as I know, the mesh time server has the capability to synchronize the time of the nodes in the mesh network and I have done some experiments. there are two CYW920735Q60EVB-01 boards
. the mesh time server firmware is downloaded into the One of the development boards. the mesh provision client firmware is downloaded into the other. the mesh provision project is configured as
follow in the makefile.mk:
C_FLAGS += -DWICED_BT_MESH_MODEL_TIME_CLIENT_INCLUDED
APP_SRC += mesh_time_client.c
use the mesh client control to create the mesh network by the board which is burned the mesh provision
client firmware. so the mesh time server device joined the mesh network.
when the time server device is joining the network
some models is automatically bound, however the time server is not automatically bound, so when I use the mesh client control to send the time server message , the time server device can not receive the message.
the application interface function for time server is the mesh_time_server_message_handler.
when I send the set time message, the function is never called.
however I think the root cause is the time server model is
not bound when the device joined the mesh network
thanks!
Mandy
Could you please try using Modustoolbox IDE?
The application is pretty much same. The latest libraries and bug fixes will be added in the latest Software (SDK) only.
Links:
MTB: https://www.cypress.com/products/modustoolbox-software-environment
Apps: GitHub - cypresssemiconductorco/mtb-examples-CYW920735Q60EVB-01-btsdk-mesh-snip: Mesh Snip Examples
-Dheeraj
