mawu_4270096
5 sign-ins First like received First like given
Hi:
   when I use the floating point calculation in the wiced studio,and there are some compile errors as below.
Unknown symbol  __aeabi_ui2d (err 0)
Unknown symbol  __aeabi_dcmplt (err 0)
Unknown symbol  __aeabi_ddiv (err 0)
Unknown symbol  __aeabi_dmul (err 0)
Unknown symbol  __aeabi_dadd (err 0)
Unknown symbol  __aeabi_dcmpgt (err 0)
Unknown symbol  __aeabi_dsub (err 0)
Unknown symbol __aeabi_i2d (err 0)
Unknown symbol  __aeabi_d2uiz (err 0)
Unknown symbol  __aeabi_d2iz (err 0)
I guess the reason is that the current  the configuration of the  wiced studio  can't  support the floating point calculation.
who can tell me how to configue the  wiced studio to support the floating point calculation.
thanks!
mandy
BoonT_56
I think this limitation is also caused by the lack of FPU in CM3, which is widely used in our BT ICs. A solution was suggested below:
Re: Floating-Point Arithmetic
SheetalJ
Hi Mandy,
Which BT chip are you using?
Can you please refer: How to enable floating point operations/FPU on the CM4 of the 20719
mawu_4270096
Hi  SheetalJ_96:
       I use the BT chip is CYW20735
20735B1 utilized the CM4 core, then Sheetalj's suggested link will be applicable to you.
mawu_4270096
Hi BoonT_56:
    thank you!
    I have solved this question according to your suggestion
