GeHo_1653746
installed SDK 6.4 and tried to run hci_audio_gateway demo to connect to a bluetooth headset (tried several).
it will connect and disconnect to the device but the audio will not turn on (the peer device thinks it's connected) .
The hci trace has a bunch of errors in it that look like issues in the underlying code , they may be a red herring but the open command never completes
the development board is a CYBT_353027_EVAL
the bt_spy log is attached.
SheetalJ
Hi GeHo_1653746​,
Could you please confirm which BT profile you want for your application? I would suggest you to go for demo/watch app in WICED SDK for A2DP source functionality if you need as it is fully tested & more reliable.
I am little doubtful that hci_audio_gateway example illustrates only the control part and not reliable for the full audio transmission. I will check more on this.
SheetalJ
Hi GeHo_1653746​,
