I am now using CYBT-343026-01 module on my board. I would like to play the module just as the HCI module. What is missing now is to load the correct hcd file to get it work. Could anyone tell me how to get it? The default device name on the module is BCM20703A2.
Hi xha_3441776,
From what I understand, you want to use CYW20706 as controller and trying to connect from an external host, right?
You can use CyBluetool (Windows Installer) or ClientControl for the same to send commands to the controller.
Please refer /20706-A2_Bluetooth/doc/WICED-HCI-Control-Protocol.pdf for commands and theory.
Hi xha_3441776,
I guess you want to put the board in HCI mode to program it further.
You can achieve this by recovering the board using recovery procedure.
- Press and hold the Recovery button (SW3).
- Press and hold the Reset (SW2) button for 1 second.
- Release SW2
- Release SW3
If you just want to generate hcd file for some particular application, then use make target with parameter DIRECT_LOAD=1.
For example,
demo.audio.headset-CYW920706WCDEVAL DIRECT_LOAD=1 build
This will generate hcd file in Build folder in WICED Studio.
sorry, it's not what I would like to do. Normally there is a patch file(hcd file) for the radio to be downloaded so that the radio could work correctly. I don't need such hcd file for any particular application.
The device inside the module is a CYW20706
Yes. I need the corresponding hcd file.
Please refer below KBA: Putting 2073x, 2070x, and 20719 Based Devices or Modules in HCI Mode – KBA225450
sorry. I could already put the device BCM20703A2 in HCI mode. But normally the device should be downloaded with a hcd file at the beginning of the initialization. Otherwise it could not work properly. For example if the device tries to find other devices, it could find nothing.
I feel there is some misconception.
Once you put the device in HCI mode, there is no need to download it with any hcd file. You can directly program the device with required application and start working.
One method to put device in HCI mode is programming it with a non-BLE project like gpio. Otherwise, there is no need to download a 'particular hcd file' at the beginning of initialization.
it's interesting. After I initialize the bt Radio and then send hci inquiry, I could not see that the device works properly. Because I could not find any devices in the near.
Can you tell which application you are downloading in the board?
Put the device in HCI mode (recover), program the device with proper application (lets say hello_client), you should be able to see nearby Bluetooth devices.
I am using the Cypress applicaiton or Cypress bt stack on the module. We are using another BT stack on our host Controller. We are trying to communicate to the bt radio with our stack.
Could you tell me what we should do if we just want to initialize the bt Radio? In other words, which hci command sequences should be sent to the bt radio to make it work properly?
sorry, just ignore the answer before. I am not using the Cypress applicaiton or Cypress bt stack on the module. We are using another BT stack on our host Controller. We are trying to communicate to the bt radio with our stack.
Hi xha_3441776,
I have already read this document. But we don't need such WICED-HCI-Control-Protocol. We could communicate with the bt Controller over some hci commands such as HCI_RESET, HCI_READ_LOCAL_NAME, HCI_READ_BUFFER_SIZE, HCI_HOST_BUFFER_SIZE and so on at the beginning. But after that if we send HCI_INQUIRY, we could not get any inquiry result from the controller.
Could you check it again if this Controller really doesn't need the patch file(hcd file) to get it worked properly?
There is no such patch or hcd file for making the board work correctly.
