We’ve been working with the BCM920707V2_EVAL for a while using the hci_handsfree_plus.
We saw that after creating an SPP connection with a device that acts as an echo server (we send data, and the device send the same data back as soon as the data received) , the time the whole data loopback takes is > 500ms. This seems to be very slow.
Do you have any suggestion on how to speed up the way “hci_handsfree_plus” processing spp data?
is there a ready to use SPP dedicated app that i can use instead of the handsfree?
FYI, our UART baud rate is 921600.
Unfortunately, the BCM20707 is not one of the products supported here on the Community website. Please reach out to the regional/local Cypress Sales and/or Distribution team that enabled you for access to this product as they will be able to line up factory support.
Hi lampertg
Can you please attach your source/firmware to this discussion?
we will have a look at it and try to test it on our side.
- MadhuSudhan
