No it doesn't.
Yes CYBT-343026-01 supports dual mode topology. It is mentioned on product page- https://www.cypress.com/documentation/datasheets/cybt-343026-01-ez-bt-wiced-module
1. Do you mean below one?
2. I don't understand what meaning of "LE dual mode topology", does it mean LE and classic?
3. Or
Does it mean "
LE slaves do not share a common
physical channel with the master. Each slave communicates on a separate physical channel with the master.
1.Yes.
2-3. Dual mode means Classic BT and BLE at same time. You can check this help article- https://stackoverflow.com/questions/14321892/bluetooth-le-dual-mode
I check the BLUETOOTH CORE SPECIFICATION Version 5.1 for
it mean "
So cybt343026-01 support this. Right?
CYBT-343026-01 is compatible with Bluetooth 5.0 as mentioned on product page, not 5.1.
so not support BLUETOOTH CORE SPECIFICATION Version 5.1 LE togology. Right?
No it doesn't.
