dear sir/madam,
we are using wicked module programmer for loading program file into cybt-343026 but every time without recovery program loading failing and also some times if module in recovey mode also not loading.
1)we are using wicked moduler programmer in windows 7 because it is not working?
2)is there any related application for loading program in cybt-343026.
3)is it possible to download program without entering recovery mode.
regards
harikrishna g
Hi Hariskrishna,
1. Yes the programmer works with Windows 7.
2,3. Yes it is mandatory to recover the board before programming it.
Please follow procedure given in user guide: Programming an EZ-BT WICED Module – KBA223428
Also, follow procedure mentioned here for CYBT-343026 module- Re: CYBT-413034-02 programming through "WICED_MOD_Programmer" app
If nothing is working, try programming the module with an empty application once and then try to load your application firmware in the module.
Hi Hariskrishna,
