GHKC
10 replies posted 10 questions asked 5 replies posted
dear madam/sir,
we are using cybt343026 module in my printer devices. for cybt343026 we are using spp example and we modified as per our requirement(added our own commands for connection between our mcu and cybt343026 module).
we are connecting to cybt343026 module to samsung mobiles(j2,m01,on7pro) without pair code. data sending from mobile to module(through bluetooth) and module to mcu(trough puart).this is our requirement.
problem:
1.when we are connecting to bluetooth one to 3 time it is connecting properly but after that bluetooth not connecting.
2.in mobile bluetooth settings bluetooth scanning  not working after restarting mobile  or flight on off then its connecting but after 1 to 3 connections again not connecting.
thanks,
hari
SheetalJ
First comment on KBA 750 replies posted 500 likes received
Hello Hari,
I am bit confused; Is connection not happening with more than 3 different devices? Or same device but more than 3 times?
FYI: Can BT search function and BT connection realized simultaneously
GHKC
hi sir
thanks for your response.
I am bit confused; Is connection not happening with more than 3 different devices? Or same device but more than 3 times?connection not happen with same device .
the 3 is not proper count it may be happen less or more also
SheetalJ
Hi Hari,
Can you please provide me the configuration you are using while testing? cfg.c file should work.
Also, Can you try testing once with another mobile phone like iPhone, Redmi or any other brand than Samsung?
GHKC
hi sir,
here i am added my config file please check and tell me where i done mistake
regards,
hari
