My first project was "hello_sensor". I used new Platform Files and created new Make Target. Everything worked. (WICED Studio 6.2.1.2 )
Then the second project was "hci_uart_gatt_service". I also did a new Make Target and downloaded it. Then I opened ClientController application. Set COM interface and downloaded the .hcd file. This download failed.
From now on i cannot even download the "hello_sensor" Make Target. Error Message in console as follows.
The Detection Failure already exists when "hello_sensor" was working. Afterwards the download messages occur.
But now it says that the file cannot be found...
07:59:49 **** Build of configuration Release for project 20706-A2_Bluetooth ****
"C:\\MeineProgramme\\WICED-Studio-6.2\\20706-A2_Bluetooth\\make.exe" demo.hello_sensor-CYBT_343026_EVAL download
Compiling platform.c
Compiling spar_setup.c
Compiling hello_sensor.c
Compiling wiced_bt_cfg.c
Compiling sparinit.c
Compiling wiced_bt_app_common.c
Compiling wiced_bt_app_hal_common.c
Compiling lib_installer.c
Linking target ELF
OK, made elf.
readelf: Warning: Bogus end-of-siblings marker detected at offset e17a in .debug_info section
readelf: Warning: Bogus end-of-siblings marker detected at offset e17b in .debug_info section
readelf: Warning: Bogus end-of-siblings marker detected at offset e17c in .debug_info section
readelf: Warning: Further warnings about bogus end-of-sibling markers suppressed
Call to hello_sensor_spar_crt_setup @ 00218efd
OK, made C:/MeineProgramme/WICED-Studio-6.2/20706-A2_Bluetooth/Wiced-BT/spar/../../build/hello_sensor-CYBT_343026_EVAL-rom-ram-Wiced-release/A_20703A2-hello_sensor-rom-ram-spar.cgs. MD5 sum is:
abff398d65e3cfca747927eea6bd7ef4 *../../build/hello_sensor-CYBT_343026_EVAL-rom-ram-Wiced-release/A_20703A2-hello_sensor-rom-ram-spar.cgs
Patches start at 0x000D0200 (RAM address)
Patches end at 0x000DD7B8 (RAM address)
Application starts at 0x00217A38 (RAM address)
Application ends at 0x00218EEC (RAM address)
Patch size 54712 bytes
Application size 5300 bytes
Total RAM footprint 60012 bytes (58.6kiB)
Converting CGS to HEX...
Conversion complete
Creating OTA images...
Conversion complete
OTA image footprint in NV is 67544 bytes
Detecting device...
********* Detection Failure *************
| The CYBT-343026-EVAL board was not detected. Verify that the device is connected, |
| power-cycle if necessary to reboot into programming mode, and retry. |
| Please see Appendix sections in the Quick Start Guide for common COM port problems. |
Das System kann die angegebene Datei nicht finden.
08:00:23 Build Finished (took 33s.312ms)
It should be OK if you already close the ClientControl. Please check the Port number in the device manager. Use the port displayed in the device mananger. For exapmle, if you found COM8 and COM9 in the device manager, add UART=COM8 in your make target.
The make target should like this: demo.hello_sensor-CYBT_343026_EVAL download UART=COM8.
I recovered the board by pressing SW2 -> pressing SW1 -> releasing SW1 -> releasing SW2. but it's still not downloading.
Did you close the HCI port in the client control when you program the device?
If not, please close the HCI port and recover the eval board. Then try to download again.
I Closed ClientControl application without closing HCI Port i guess. Used COM was COM4 and COM5. No there are COM 8 and COM9 available.
What can i do now??
Thank you!!!
I made a Make Target as u described. Then the console reads "downloading application..." but it failed.
I recovered the board and included plattformfiles again.
Now it works!
