daba_4649501
10 replies posted 5 replies posted 5 questions asked
hello,
i am using CYBT-413034-02 and CYBT-413055 ble chips and i am programming this modules using evaluation board of HCI uart and PUART through USB serial.
can i able to configure the HCI uart as normal for flashing an external memory after programming the module. i only need rx and tx for the flashing external serial flash.
also i need to use PUART for the trace.
i dont know if it possible , if there is please let me know.
thank you,
regards,
danny.MichaelF_56SheetalJ_96broadcomwiced-adminDaZh_2976111
If you are planning to program the cypress chip using an external MCU, you can refer WICED-HCI-Control-Protocol.pdf This document will show us how a host microcontroller unit (MCU) can communicate with a Cypress WICED device via HCI UART.
You can refer the lab manual examples (Chapter5) to understand how HCI modes and communications are coded.
CypressAcademy_WBT101_Files/Projects/ch05 at master · cypresssemiconductorco/CypressAcademy_WBT101_F...
Please check wiced_transport.h for related transport utility APIs and descriptions.
-Dheeraj
