I'm using CYBT-483039 device and i need to download Wiced Studio 6.4. I tried to download it from this link "https://community.infineon.com/t5/Public-Archive/WICED-Studio-6-4-0-Installer-Windows/td-p/259228" but when i click on "Click here for a High performance download of the WICED-Studio 6.4.0 Installer (Windows) through Akamai", I'm redirected to MyInfineon Homepage so the link is broken.
How can I download Wiced Studio 6.4?
I can't use Wiced Studio 6.2 becouse for our application we need to set transmit power at 20 dbm and with Wiced Studio 6.2 i'm not able to set transmit power over than 4 dbm.
Hello @drago
I had a discussion with our marketing team. As all of our broad market BTBLE chips are supported through MTB IDE , we are not releasing WICED SDK old versions. WICED 6.6 will be available which supports only the combo devices.
If you need any special releases you have to contact via local sales / FAE.
Sorry for the inconvenience caused at your side.
Anjana
Hello @drago
We are checking on this website issue. Will fix this soon.
Sorry for the inconvenience.
Anjana
Hi @AnjanaM_61
Thanks for the reply,
could you tell me when the problem will be solved more or less?
Hello @drago
Anjana
评估测试
