I ported the SPP to other routines.However, the RFCOMM registration fails
call wiced_bt_rfcomm_create_connection()
rfcomm_result = 6/8
check wiced_bt_rfcomm_result_t
6 = WICED_BT_RFCOMM_NO_RESOURCES, /**< No Resources */
8 = WICED_BT_RFCOMM_INVALID_MTU, /**< Invalid MTU */
I've seen it many times
But add the other code you need in the routine that contains the SPP.
There will be no such error
@mifo
Hi
Not sure if this issue fixed for you. Could you please try the below suggestions:
1: Could you please increase the buffer pool sizes in the wiced_bt_cfg.c file . Example:
const wiced_bt_cfg_buf_pool_t wiced_bt_cfg_buf_pools[WICED_BT_CFG_NUM_BUF_POOLS] =
/* { buf_size, buf_count, }, */
{ 64, 16, }, /* Small Buffer Pool */
{ 272, 8, }, /* Medium Buffer Pool (used for HCI & RFCOMM control messages, min recommended size is 360) */
{ 1056, 3, }, /* Large Buffer Pool (used for HCI ACL messages) */
{ 1056, 2, }, /* Extra Large Buffer Pool (used for SDP Discovery) */
2: As of now, I can see the MTU size in the config file of your project is set to 365. Could you please set max_mtu_size to 515 . Please try the above modifications first.
3: If still not working, can you please change the buffer size passing to API wiced_bt_rfcomm_init and let us know the API result.
4: Not sure how did you tested the project. Please let me know
5: If your requirement is just to merge A2dp sink + SPP profile. Can you try it with the APIs in spp.c ,(removing the hci_control_spp ) and please let us know the API results if not working.
