In a hands-free application using BLE communication,
What is an effective way to reduce power consumption?
The power save option is not available in my application.
CYW20706 is the main host, so I can't use the deep sleep mode.
And the application is using a periodic timer(several tens of milliseconds),
so I can't use the low power sleep mode.
Please give me some advice on waht to do.
Thank you!
Hi Aaron,
When you say 'handsfree' are you referring to HFP? What are you using BLE for?
Have you read this article? CYW20706 – BLE Low Power Beacon
You could use the wiced_sleep_config() API to reduce power consumption but if a applicaiton timer is running always, then I don't think there will be any power reduction.
You should be looking at reducing power by changing Tx power or intervals or slave latency (for BLE).
