YaTr_3516311
25 sign-ins First solution authored 100 replies posted
I'm testing "HCI Commands for a RAM Download". When I go to WRITE_RAM command, it says
"xx xx xx xx is the 4-byte, absolute RAM address." I don't know what is absolute RAM address, where can I get this parameter? I used CYBT-343026-01 EVAL board to do the testing.
BR,
Treacy
SheetalJ
First comment on KBA 750 replies posted 500 likes received
Hi Treacy,
Absolute address is nothing but the address specified explicitly, in a clear and detailed manner. WICED HCI Control protocol pdf gives more details about this
SheetalJ
Hi Treacy,
So in normal case, I fill 0x220000 to be the address for this command for the start?
No, that location is given for example in document. Following threads might be helpful for you, they address same query-
CYW20706 Memory Layout
Re: [CYBT-343026-01] Be forced to execute WRITE_RAM
Re: Programming SPI Flash in CB-343026-01 Module
