hi there,
I am attempting to install WICDE studio on my MacBook, but the results are a bit different than listed in the instructions, here:
WICED-Studio 6.4.0 Installer (OSX)
OSX says "the installer cannot be open".
Has this been tested yet on 10.15.3?
thanks,
-Tyler
Have you tried the work around that is mentioned in WICED-Studio 6.4.0 Installer (OSX) ?
If so, could you try uninstalling WICED and removing all files related to it and try again.
Hi
Could you please confirm if you have given permission for apps downloaded from other than the APP store to be installed on your MAC as mentioned in Safely open apps on your Mac - Apple Support
yes it is. No difference in behavior. jdk 8 is installed as well:
ls /Library/Java/JavaVirtualMachines/
jdk-12.0.1.jdk/ jdk1.8.0_241.jdk/ openjdk-13.0.2.jdk/
