Studio Bluetooth
NaDo_1344206
Welcome!
I tried to modify example project available in WICED but not able to do so as per attached snapshot, but its creating multiple errors.
Please help on same to resolve issue quickly and to move forward quickly.
Let me know if any further details needed from my side.
SheetalJ
Moderator 750 replies posted 500 likes received 500 replies posted
Please try changing your device name to less than 8bit characters as advertisement packets is only 32 bytes long.
Use default hello sensor project. Please follow the correct programming procedure- Programming an EZ-BT WICED Module – KBA223428
I see many errors in your snapshots attached; Check if you are using correct files, makefile.
