Hello together,
I am going to start a development project based on CYBT-413055(-EVAL). So, assume that I am a newbee.
As always the simplest things are creating huge problems ...
So, I would like to use WICED Studio (OSX) on my MAC (OSX 10.15.7). I followed the special instruction for Mac of MichaelF_56 at https://community.cypress.com/docs/DOC-21414 but I always get the same error: „WICED-Studio-6.6.0.9-IDE-Installer.app“ cannot be opened. That it?! Should my attempts end up here ?
Please, if you have any idea let me know.
A
Thanks ChunleiL_51
that is what I did....
Finally I was making it by following one note in the Release Notes: WICED Studio 6.6.0
Under point 4 Known Issues your find the following, which helped to overcome the issue:
- Starting MacOS Catalina, to install WICED Studio, the user has to modify the security settings to Allow apps downloaded from “App Store and identified developers”. Open terminal window navigate to the path where the installer is located and execute the following commands:
>chmod +x WICED-Studio-6.6.0xxxx.app/Contents/MacOS/*
>open WICED-Studio-6.6.0xxxx.app
Ensure that you download the file correctly. The hash of file BM-OSX-WICED-Studio-6.6.0.9-IDE-Installer.app.zip using algorithm SHA256 is: 203C094EE38344E703D74FBD578D08638122E8B5855DD2E25E19F62E41F1E09A.
Then follow the KBA WICED-Studio 6.6.0 (OSX) and don't miss the details.
Thanks ChunleiL_51
