ilHw_4713311
First solution authored 25 replies posted 10 replies posted
Hello.
Module: CYBT-413034-02
I want to use "WICED_MOD_Programmer" for update firmware S/W.(WICED_MOD_Prog_v1.5.19.102)
But it failed. I have no idea. Can you please let me know?
Logs
27-08-2020 09:42:32.663: WICEDModuleProg: Test program stopped.
27-08-2020 09:42:50.940: ProgramManager: Selecting_DUT 1/8
27-08-2020 09:42:51.083: Prog[0]COM41 : Reset DUT to HCI mode instead of Recover mode.
27-08-2020 09:42:51.417: ProgKit423028COM41: Exception on Pull Dut#1 CTS_Pin to LowSystem.TimeoutException: 작업 시간을 초과했습니다.
   위치: System.IO.Ports.SerialStream.ReadByte(Int32 timeout)
   위치: System.IO.Ports.SerialStream.ReadByte()
   위치: System.IO.Ports.SerialPort.ReadByte()
   위치: CyBLE_MTK_Application.ProgBoard.PullDutPin_SAMI265(Int32 DutNo, DutPinName PinName, PullState PullTo, Int32 WaitTime)
27-08-2020 09:42:51.678: ProgKit423028COM41: Exception on Pull Dut#1 XRES_Pin to LowSystem.TimeoutException: 작업 시간을 초과했습니다.
27-08-2020 09:42:51.956: ProgKit423028COM41: Exception on Pull Dut#1 XRES_Pin to HighSystem.TimeoutException: 작업 시간을 초과했습니다.
27-08-2020 09:42:52.128: ModeSelectBCM20719: Reset DUT#1 to HCI
27-08-2020 09:42:53.446: Prog[0]COM41 : Reset (COM41) Timeout!
27-08-2020 09:42:53.453: Prog[0]COM41 : Soft-Reset Fail COM41
27-08-2020 09:42:53.460: Prog[0]COM41 : Failed to reset on baudrate = 115200
27-08-2020 09:42:53.472: Prog[0]COM41 : Failed to reset DUT
27-08-2020 09:42:53.485: ProgramManager: ---->SetResult [1,1] = TestFailed
27-08-2020 09:42:53.561: ProgramManager: Selecting_DUT 2/8
27-08-2020 09:42:53.585: ProgramManager: Selecting_DUT 3/8
27-08-2020 09:42:53.613: ProgramManager: Selecting_DUT 4/8
27-08-2020 09:42:53.650: ProgramManager: Selecting_DUT 5/8
27-08-2020 09:42:53.808: ProgramManager: Selecting_DUT 6/8
27-08-2020 09:42:53.904: ProgramManager: Selecting_DUT 7/8
27-08-2020 09:42:54.043: ProgramManager: Selecting_DUT 8/8
27-08-2020 09:42:54.511: WICEDModuleProg: Test program stopped.
SheetalJ
Hi ilHw_4713311​,
Have you selected correct COM port & it is not open anywhere else?
Please check configuration in following threads, hope it helps:
CYBT-413034-02 programming through "WICED_MOD_Programmer" app
Programming CYBT-413034-02-EVAL
SheetalJ
Hi ilHw_4713311​,
ilHw_4713311
Thanks!
I had to press recover button on Ev board when updating Firmware.
