I am using CYBT 423028 Eval for Mesh development (Dimmer code), to debug or to check WICED trace messages on Putty, configured WICED_BT_TRACE through PURT.
After code download disconnected the HCI UART to get trace messages on PuTTY. But I am getting some garbage messages as shown below.
Followed the steps to check Trace messages:
1. Downloaded the code.
2. turn off the HCI UART switch
3. Turn On PURT switch
4 Configured PuTTY (See image below)
Is there anything i am doing wrong of missing to get proper trace messages.
With same configuration as mentioned above i could able to get Trace messages for GPIO project. but not with the Dimmer code.
Could you please try changing the baud rate to 921600, if you are using mesh apps?
Default baud rates for almost all apps except mesh is 115200.
-Dheeraj
-Dheeraj
