I have a MCU to connect Cybt-343026-01 via puart. I want to upgrade bt modul’s FW. For example, puart receive a defined command, then transmit the needed fw data via puart. Is it Ok? I know I can use HCI uart command, but now I just connect mcu to bt via puart. and I see “wicked-hci-protocol” and “hci-uar-spi-bridge“ exampl, need SPI? I’m confuse.just connect mcu to bt via puart ok or no? or need other hardware pin needed?
Yes. It should be OK. Please be aware that the puart can only be used for upgrade. If you want to download FW, you must use the HCI UART with flow control.
You can upgrade the FW through OTA, SPI or UART. But we only have code example for OTA.
Please refer to the doc/WICED Firmware Upgrade Library.pdf in the SDK for some details.
I see. So MCU with cybt343026-01 only connect with puart is OK(four pins). Right? No need other hardware connection?
