assh_3716096
Hi everyone !!!
I created a project and code is not being compiled due to a floating point multiplication. The line that is causing a compilation error is
lux = (1 << Exponent) * 0.01;
Without floating point multiplication, code compiles successfully.
The compilation error generated is
undefined reference to `__aeabi_d2f'
What can be done to solve this issue?
Could you please confirm which chip are you using?
The chips like CYW20719 which is CM4 will support float operations.
Anjana
AnjanaM_61
10 questions asked 5 comments on KBA First comment on KBA
Hi Anjana,
I'm interested in floating point calculations, however example that you pointed to shows how to print floating point numbers.
Anjana
