Hi Sir,
I have installed Winced studio 6.2 ,when I build hello_sensor, there are some errors ,eg.
Description | Resource | Path | Location | Type |
Symbol 'HANDLE_HSENS_BATTERY_SERVICE' could not be resolved | hello_sensor.c | /20706-A2_Bluetooth/apps/demo/hello_sensor | line 190 | Semantic Error |
How to correct it?
Hi Xiapping
The HANDLE_HSENS_BATTERY_SERVICE = 0x60, can be found in hello_sesor.h.
And I believe the error is post in tap of "Problems" as bellow, right? If so, just ignore it as the project's build result is showed in tap of "Console" logs: like"Build Finished" means build success.
Hi Xiapping
Thank you very much!
