Hi:
I have read this:
CYW20719 in HCI mode https://community.cypress.com/message/162494?tdsourcetag=s_pcqq_aiomsg
As my known:
CYW20719/CYW20819 can work in standard HCI mode or Application mode depending on whether a valid application image loaded.
I have test both modes and it works fine.
My question is :
Is there any possible that I can use standard hci interface in application mode ?
If yes, the external MCU is unneeded, then we can port our own bluetooth stack (override the build-in stack) to CYW20719 as well.
Current:
Standard HCI + External MCU(host stack)
Cypress HCI + Internal MCU (Cypress host stack)
What we want:
Standard HCI + Internal MCU(our own host stack running inside Application_Start(){..})
Thansk!!!
As you mentioned the only options are Standard HCI + Cypress host stack , Standard HCI + External host stack( MCU / Android / Bluez etc).
Standard HCI + Internal MCU(our own host stack running inside Application_Start(){..}) won't be feasible.
Thanks & Regards,
Anjana
