towa_2281366
5 sign-ins First solution authored First reply posted
Hi:
     I have read this:
     CYW20719 in HCI mode https://community.cypress.com/message/162494?tdsourcetag=s_pcqq_aiomsg
     As my known:
     CYW20719/CYW20819 can work in standard HCI mode or Application mode depending on whether a valid application image loaded.
     I have test both modes and it works fine.
     My question is :
          Is there any possible that  I can use standard hci interface in application mode ?
          If yes, the external MCU is unneeded, then we can port our own bluetooth stack (override the build-in stack) to CYW20719 as well.
     Current:
     Standard HCI + External MCU(host stack)
     Cypress HCI +  Internal MCU (Cypress host stack)
     What we want:
     Standard HCI + Internal MCU(our own host stack running inside Application_Start(){..})
     Thansk!!!
AnjanaM_61
First comment on KBA 5 questions asked First question asked
As you mentioned the only options are Standard HCI + Cypress host stack , Standard HCI + External host stack( MCU / Android / Bluez etc).
Standard HCI + Internal MCU(our own host stack running inside Application_Start(){..}) won't be feasible.
Thanks & Regards,
Anjana
AnjanaM_61
Thanks & Regards,
Anjana
