Oct 22, 2021
06:02 AM
Oct 22, 2021
06:02 AM
I'm porting WICED to a STM32H733 and I've an issue with the code snip.bluetooth.ble_gatt_db.c. The function "wiced_bt_stack_init( ..);" is not working.
I've this:
00:00:00.023000 GKI_create_task func=0x80932f9 id=1 name=BTU stack=0x0 stackSize=4096
00:00:00.031000 GKI_create_task func=0x8094ae5 id=0 name=HCISU stack=0x0 stackSize=3072
00:00:00.040000 --
00:00:00.042000 SENT Command to HCI. Name: HCI_Reset (Hex Code: 0x0c03 Param Len: 0) Ctrl(0)
00:00:00.051000 --
00:00:04.042000 --
00:00:04.044000 SENT Command to HCI. Name: HCI_Reset (Hex Code: 0x0c03 Param Len: 0) Ctrl(0)
00:00:04.052000 --
I change platform files but nothing happens on BT_REG_ON or UART_TX.
Do you know were I can found the code to recompile and perform step by step debugger?
Thank you,
Jean
Labels
WICED Studio Bluetooth
12:32 AM
Dec 22, 2021
12:32 AM
Hello @jbiemar46456
Currently we don't support STM32H + 4343W on WICED. We will check if there is any resources available to share on porting to STM32H7 and update you.
Meanwhile, in your case , can you try sending some Bluetooth specific commands after the patchram download & see if you get any response for that ?
Anjana
