I am using CYBT-343026-EVAL with WICED 6.2 now.
I know recovery todo 1~5 like below.
1. Press and hold RECOVER button (SW2) |
2. Press and hold RESET button (SW1) for 1 second |
3. Release SW1 |
4. Release SW2 |
5. Re-program the board
I am wonder whether below items are deleted after recover.
1.The software that downloaded to CYBT-343026-EVAL.
2.The bd_address of paried device.shjlgoto-t_2353976user_140663973user_437857088axel.lin_1746341
ispn:40226:1:0
l1:314:1:0
Hi y-zhang_3572401
Apologies for the confusion.! In clear words, nothing will get deleted after recovery. Program and bonding information (BD address) will be there until you reprogram it.
Hi y-zhang_3572401
After recovery of the board,
1. the app downloaded to your board will be deleted
2. BD address of the paired device will also be deleted.
Hi,shjl
I downloaded Audio Gateway software to the board,and recovered the board.
After that,I press the reset button of the board.
I can also see the trace log that I maked before which the software is I downloaded to the board.
Hi y-zhang_3572401
To be clear, when you recover the board, the board will enter the auto-baud mode, which means the device will think that the flash is corrupted. Whether as when you reset the device after recovery, the device will come out of auto-baud mode, whatever is there in flash will be read and therefore you see the logs of the previous software because you have not overwritten it by programming again.
So exact answer of your question can be, the program does not get deleted but recovery gives you the permission to overwrite it with your new program.
Thank you for your answer.
Recover does not delete the software that downloaded to CYBT-343026-EVAL
Please let check it again,Is it correct?
Yes this is correct.!
Could you tell me that Which memory is deleted after recover ?
Serial Flash memor,or RAM memory,ROM memory?
When you program the board, application will be loaded into flash, then gets copied to RAM and from there it executes.
After you do recovery and press reset, the code will again execute from the RAM. So ideally, nothing gets deleted.
Rom is untouched here.
Sheetal
Sorry,I am confused.
and the new answer is >nothing gets deleted.
Will BD adrress remain or not after recover.
Could you give a clear answer about this?shjlaxel.lin_1746341goto-t_2353976user_437857088user_140663973
Hi y-zhang_3572401
