Apr 10, 2018
06:46 PM
Apr 10, 2018
06:46 PM
I am development the test code for CYW20704UA2KFFB1G, there is a external SPI flash memory, MX25L2006EM1L-12G(2M), connected to the chip via D7,D8,E7,E8 pins.
How can I initialize the flash memory and do the read/write function by HCI command using the UART interface ?
I am using the Bluez 5, is there any example or document I can take reference?
Can I develop the test code based on bluez or I must use the BSA package to access/program the SPI interface on CYW20704?
Thanks for your help.
01:36 AM
Apr 13, 2018
01:36 AM
20704 is currently not supported in this forum. You may have to revert to the Taiwan team that enable you on this.
