As a follow on to this closed thread: CYW20706 Mesh APP "MeshLighting.apk" Forced Termination in the Android 7.0
The MeshLightingController.apk was not able to work on Android 9 platform. When I launched the APP on Pixel device, it show me "failed to open the network". And When I was trying to Create Network and fill a name then press ok, it show me nothing. Here is the log :
2018-12-18 19:05:03.872 1253-1253/com.cypress.le.mesh.meshapp D/FragmentRoom: User clicked OK buttontest
2018-12-18 19:05:03.872 1253-1253/com.cypress.le.mesh.meshapp D/LightingService: getCurrentNetwork = null
2018-12-18 19:05:03.872 1253-1253/com.cypress.le.mesh.meshapp D/FragmentRoom: mApp.getMesh() is not null
2018-12-18 19:05:03.872 1253-1253/com.cypress.le.mesh.meshapp D/MeshController: getAllNetworks
2018-12-18 19:05:03.872 1253-1253/com.cypress.le.mesh.meshapp E/Jni: _meshClientGetAllNetworks 9
2018-12-18 19:05:03.873 1253-1253/com.cypress.le.mesh.meshapp I/MeshLibrary: wiced_bt_mesh_db_get_all_networks
2018-12-18 19:05:03.873 1253-1253/com.cypress.le.mesh.meshapp I/MeshLibrary: wiced_bt_mesh_db_get_all_networks log
2018-12-18 19:05:03.873 1253-1253/com.cypress.le.mesh.meshapp E/Jni: _meshClientGetAllNetworks 10
2018-12-18 19:05:03.873 1253-1253/com.cypress.le.mesh.meshapp E/Jni: Name***:
2018-12-18 19:05:03.873 1253-1253/com.cypress.le.mesh.meshapp E/Jni: val***:0
2018-12-18 19:05:03.873 1253-1253/com.cypress.le.mesh.meshapp D/FragmentRoom: currentNetwork==null
2018-12-18 19:05:03.874 1253-1253/com.cypress.le.mesh.meshapp D/FragmentRoom: currentNetwork : null
2018-12-18 19:05:03.874 1253-1253/com.cypress.le.mesh.meshapp D/MeshController: createNetwork
2018-12-18 19:05:03.874 1253-1253/com.cypress.le.mesh.meshapp D/MeshController: openNetwork
2018-12-18 19:05:03.874 1253-1253/com.cypress.le.mesh.meshapp E/FragmentRoom: failed to open network!!
2018-12-18 19:05:03.876 13921-15503/? D/audio_route: Apply path: speaker
2018-12-18 19:05:03.876 13921-15503/? D/audio_hw_primary: enable_snd_device: snd_device(102: vi-feedback)
2018-12-18 19:05:03.876 13921-15503/? D/audio_route: Apply path: vi-feedback
2018-12-18 19:05:03.876 13921-15503/? E/audio_hw_utils: audio_extn_utils_send_app_type_cfg: Failed to derive app_type for uc type : 0x1
2018-12-18 19:05:03.876 13921-15503/? D/ACDB-LOADER: ACDB -> send_audio_cal, acdb_id = 512, path = 1, app id = 0x11132, sample rate = 48000
2018-12-18 19:05:03.876 13921-15503/? D/ACDB-LOADER: ACDB -> send_asm_topology
2018-12-18 19:05:03.876 13921-15503/? D/ACDB-LOADER: ACDB -> ACDB_CMD_GET_AUDPROC_STREAM_TOPOLOGY_ID
2018-12-18 19:05:03.876 13921-15503/? D/ACDB-LOADER: ACDB -> send_adm_topology
2018-12-18 19:05:03.876 13921-15503/? D/ACDB-LOADER: ACDB -> ACDB_CMD_GET_AUDPROC_COMMON_TOPOLOGY_ID
2018-12-18 19:05:03.876 13921-15503/? D/ACDB-LOADER: ACDB -> send_audtable
2018-12-18 19:05:03.876 13921-15503/? D/ACDB-LOADER: ACDB -> ACDB_CMD_GET_AUDPROC_COMMON_TABLE_SIZE
2018-12-18 19:05:03.876 13921-15503/? D/ACDB-LOADER: ACDB -> AUDIO_SET_AUDPROC_CAL
2018-12-18 19:05:03.876 13921-15503/? D/ACDB-LOADER: ACDB -> send_audvoltable
2018-12-18 19:05:03.876 13921-15503/? D/ACDB-LOADER: ACDB -> ACDB_CMD_GET_AUDPROC_VOL_STEP_TABLE_SIZE
2018-12-18 19:05:03.876 13921-15503/? D/ACDB-LOADER: ACDB -> ACDB_CMD_GET_AUDPROC_GAIN_DEP_STEP_TABLE, vol index 0
2018-12-18 19:05:03.876 13921-15503/? E/ACDB-LOADER: Error: ACDB AudProc vol returned = -19
2018-12-18 19:05:03.876 13921-15503/? D/ACDB-LOADER: ACDB -> AUDIO_SET_VOL_CAL cal type = 12
2018-12-18 19:05:03.876 13921-15503/? D/ACDB-LOADER: ACDB -> ACDB_CMD_GET_AUDPROC_STREAM_TABLE_SIZE
2018-12-18 19:05:03.877 13921-15503/? D/ACDB-LOADER: ACDB -> send_audstrmtable
2018-12-18 19:05:03.877 13921-15503/? D/ACDB-LOADER: ACDB -> ACDB_CMD_GET_AUDPROC_STREAM_TABLE_V2
2018-12-18 19:05:03.877 13921-15503/? D/ACDB-LOADER: ACDB -> audstrm_cal->cal_type.cal_data.cal_size = 16
2018-12-18 19:05:03.877 13921-15503/? D/ACDB-LOADER: ACDB -> send_afe_topology
2018-12-18 19:05:03.877 13921-15503/? D/ACDB-LOADER: ACDB -> ACDB_CMD_GET_AFE_TOPOLOGY_ID
2018-12-18 19:05:03.877 13921-15503/? D/ACDB-LOADER: ACDB -> GET_AFE_TOPOLOGY_ID for adcd_id 512, Topology Id 10001ccc
2018-12-18 19:05:03.877 13921-15503/? D/ACDB-LOADER: ACDB -> send_afe_cal
2018-12-18 19:05:03.877 13921-15503/? D/ACDB-LOADER: ACDB -> ACDB_CMD_GET_AFE_COMMON_TABLE_SIZE
2018-12-18 19:05:03.877 13921-15503/? D/ACDB-LOADER: ACDB -> AUDIO_SET_AFE_CAL
2018-12-18 19:05:03.877 13921-15503/? D/ACDB-LOADER: ACDB -> send_hw_delay : acdb_id = 512 path = 1
2018-12-18 19:05:03.877 13921-15503/? D/ACDB-LOADER: ACDB -> ACDB_AVSYNC_INFO: ACDB_CMD_GET_DEVICE_PROPERTY
2018-12-18 19:05:03.877 13921-15503/? D/audio_hw_primary: enable_audio_route: usecase(24) apply and update mixer path: spkr-vi-record vi-feedback
2018-12-18 19:05:03.877 13921-15503/? D/audio_route: Apply path: spkr-vi-record vi-feedback
2018-12-18 19:05:03.877 791-791/? D/android.hardware.power@1.3-service.crosshatch-libperfmgr: AUDIO STREAMING ON
2018-12-18 19:05:03.884 1253-1271/com.cypress.le.mesh.meshapp D/OpenGLRenderer: endAllActiveAnimators on 0xcdd97f00 (RippleDrawable) with handle 0xce54c810
2018-12-18 19:05:03.904 14191-14191/? I/PhenotypeExpConfig: refreshConfiguration() : Force = false : UpdateAvailable = false : Age = 1900 minutes : MaxAge = 720 minutes
2018-12-18 19:05:03.906 14191-14191/? I/LatinIme: abortComposing()
2018-12-18 19:05:03.907 14191-14191/? I/Delight5Decoder: abortComposing() : input state id = 201
2018-12-18 19:05:03.907 14191-14191/? I/LatinIme: onDeactivate()
2018-12-18 19:05:03.913 14191-14191/? I/GoogleInputMethod: onStartInput() : Dummy InputConnection bound
2018-12-18 19:05:03.914 13921-15503/? D/ACDB-LOADER: ACDB -> send_audio_cal, acdb_id = 513, path = 0, app id = 0x11130, sample rate = 48000
2018-12-18 19:05:03.914 13921-15503/? D/ACDB-LOADER: ACDB -> send_asm_topology
2018-12-18 19:05:03.914 13921-15503/? D/ACDB-LOADER: ACDB -> ACDB_CMD_GET_AUDPROC_STREAM_TOPOLOGY_ID
2018-12-18 19:05:03.914 13921-15503/? D/ACDB-LOADER: ACDB -> send_adm_topology
2018-12-18 19:05:03.914 13921-15503/? D/ACDB-LOADER: ACDB -> ACDB_CMD_GET_AUDPROC_COMMON_TOPOLOGY_ID
2018-12-18 19:05:03.914 13921-15503/? D/ACDB-LOADER: ACDB -> send_audtable
2018-12-18 19:05:03.914 13921-15503/? D/ACDB-LOADER: ACDB -> ACDB_CMD_GET_AUDPROC_COMMON_TABLE_SIZE
2018-12-18 19:05:03.914 13921-15503/? D/ACDB-LOADER: ACDB -> AUDIO_SET_AUDPROC_CAL
2018-12-18 19:05:03.914 13921-15503/? D/ACDB-LOADER: ACDB -> send_audvoltable
2018-12-18 19:05:03.914 13921-15503/? D/ACDB-LOADER: ACDB -> ACDB_CMD_GET_AUDPROC_VOL_STEP_TABLE_SIZE
2018-12-18 19:05:03.914 13921-15503/? D/ACDB-LOADER: ACDB -> ACDB_CMD_GET_AUDPROC_GAIN_DEP_STEP_TABLE, vol index 0
2018-12-18 19:05:03.914 13921-15503/? E/ACDB-LOADER: Error: ACDB AudProc vol returned = -19
2018-12-18 19:05:03.914 13921-15503/? D/ACDB-LOADER: ACDB -> AUDIO_SET_VOL_CAL cal type = 12
2018-12-18 19:05:03.914 13921-15503/? D/ACDB-LOADER: ACDB -> ACDB_CMD_GET_AUDPROC_STREAM_TABLE_SIZE
2018-12-18 19:05:03.914 13921-15503/? D/ACDB-LOADER: ACDB -> send_audstrmtable
2018-12-18 19:05:03.914 13921-15503/? D/ACDB-LOADER: ACDB -> ACDB_CMD_GET_AUDPROC_STREAM_TABLE_V2
2018-12-18 19:05:03.914 13921-15503/? D/ACDB-LOADER: ACDB -> audstrm_cal->cal_type.cal_data.cal_size = 456
2018-12-18 19:05:03.914 13921-15503/? D/ACDB-LOADER: ACDB -> send_afe_topology
2018-12-18 19:05:03.914 13921-15503/? D/ACDB-LOADER: ACDB -> ACDB_CMD_GET_AFE_TOPOLOGY_ID
2018-12-18 19:05:03.914 13921-15503/? D/ACDB-LOADER: ACDB -> GET_AFE_TOPOLOGY_ID for adcd_id 513, Topology Id 10000ccc
2018-12-18 19:05:03.914 13921-15503/? D/ACDB-LOADER: ACDB -> send_afe_cal
2018-12-18 19:05:03.914 13921-15503/? D/ACDB-LOADER: ACDB -> ACDB_CMD_GET_AFE_COMMON_TABLE_SIZE
2018-12-18 19:05:03.914 13921-15503/? D/ACDB-LOADER: ACDB -> AUDIO_SET_AFE_CAL
2018-12-18 19:05:03.914 13921-15503/? D/ACDB-LOADER: ACDB -> send_hw_delay : acdb_id = 513 path = 0
2018-12-18 19:05:03.914 13921-15503/? D/ACDB-LOADER: ACDB -> ACDB_AVSYNC_INFO: ACDB_CMD_GET_DEVICE_PROPERTY
2018-12-18 19:05:03.914 13921-15503/? D/audio_hw_primary: enable_audio_route: usecase(1) apply and update mixer path: low-latency-playback speaker
2018-12-18 19:05:03.914 13921-15503/? D/audio_route: Apply path: low-latency-playback speaker
2018-12-18 19:05:03.917 14191-1346/? I/DlamWrapper: close(): Successfully wrote DLAM properties file.
Do you have any idea about this?
There was some issue with earlier releases for the scenario when user is not logged in to their Google account. Please recheck that.
It may take quite time on investigating the problem of the app in Android 9. Meanwhile please use below version mobile phones.
Anjana
