We have a custom board in which we are using CYW920719B1 device. We have an I2C device on it, and an SPI NAND Micron memory on it.
While configuring the pins, I noticed that the preassigned configuration shows the following in SuperMux.wsm file:
<gpio name="WICED_P25" preassigned="WICED_I2C_1_SCL" enabled="yes" /> <gpio name="WICED_P29" preassigned="WICED_I2C_1_SDA" enabled="yes" /> |
On our board, we have 'wired' WICED_P29 to the SCL, and WICED_P0 to the SDA ports of our I2C device. So, will the following customization for our board work, or cause a problem?
<gpio name="WICED_P29" preassigned="WICED_I2C_1_SCL" enabled="yes" /> <gpio name="WICED_P00" preassigned="WICED_I2C_1_SDA" enabled="yes" /> |
We are using Wiced Studio 6.4.
Thanks in advance for your reply.
PK
According to the datasheet:
SCL and SDA lines can be routed to any of the P0-P39 GPIOs allowing for flexible system configuration. When used as SCL/SDA the GPIOs go into open drain mode and require an external pull-up for proper operation. I2C block does not support multi master capability by either master/slave devices.
