- Email to a Friend
Hello! I'm using the CYBT-343026-01 module and I've been having problems with the packetization modes of CYSPP. (I'm sending messages via BT and recieving it on PUART)
I was using the deafult anticipated mode but It was sending corrupted messages with a baud rate of 9600. So i decided to change to Immediate mode and it worked perfectly. My problem is that sometimes the module doesn't "remember" it's in immediate mode and works in anticipated mode aparently (It's sending corrupted messages).
When this happens I send a .CYSPPGK command to get the packetization mode, and it indicates its on immediate mode despite it's not working that way.
UART Commands:
13:48:55.836 -> .CYSPPGK
13:48:55.836 -> @R,0022,.CYSPPGK,0000,M=00,W=0A,L=14,E=0D
How can I make the module to always work correctly? Is there some parameter I'm missing to configure?
WICED Studio Bluetooth
- Email to a Friend
I checked the commands and they offer little to tune.
I think the problem could be caused by data overflow in the UART RX software buffer size.
You can try to:
- Enable flow control (CTS/RTS) on your UART link.
- Use a sniffer to capture the airlog, to verify if the module had transferred all the data correctly in sequence.
- Email to a Friend
There could be some settings to configure this. Please wait while I'm reprising the issue and find the answer for you.
- Email to a Friend
Thanks! I am looking forward to your response.
- Email to a Friend
Do you have any news on this matter?
- Email to a Friend
You can try to:
