On the peripheral UART of CYBT-413034-02
YoLe_2465781
I'm drawing a schematic around CYBT-413034-02.
Can 23-pin (UART_CTS_N) and 24-pin (UART_RTS_N) be used as a Peripheral UART?
Thanks and Regards,
YM Lee
SheetalJ
First comment on KBA 750 replies posted 500 likes received
Hi YM Lee,
These both are HCI UART pins and can't be used as Peripheral UART.
SheetalJ
Hi YM Lee,
Thank you for your kind response.
BoonT_56
It also means that you will have to select any 4 GPIOs to implement pUART. Refer to table 4 of the module datasheet for the definition of each pin pad and table 5 for the supermux IOs.
Thank you for your additional information.
