OTA function implementation
YaTr_3516311
25 sign-ins First solution authored 100 replies posted
I'm custom a FW for CYBT-343206-01. I'm afraid there may will bugs in the FW, so I want to add OTA function.I have tested EZ-serail OTA function using BLE Connection. I think I need to realize OTA function like this because if product offer to client, this way is convenient.
My quesion is:
1. What is the flash arrangement in CYBT-343206-01 module? Do you have any related document?
2. How to implement OTA function? Refer to the ota_firmware_upgrade demo in WICED-Studio?
BR,
Treacy
AnjanaM_61
10 questions asked 5 comments on KBA First comment on KBA
Hi Treacy,
Please go through the WICED-Firmware-Upgrade-Library.pdf available in WICED SDK Doc ( /20706-A2_Bluetooth/doc/WICED-Firmware-Upgrade-Library.pdf  )
For adding OTA function, please refer to the code example and the comments given in the code example and fw_upgrade_lib files.
You may also refer to some of the points in the attached doc for help.
Anjana
AnjanaM_61
Hi Treacy,
Anjana
