NeDh_4602711
50 replies posted 25 replies posted 25 sign-ins
I am using WICED Studio 6.2 with CYBT-343026-01. I have around 400 CYBT-343026-01 modules and I want to flash my firmware into it. how can I flash my firmware in all CYBT-343026-01 without connecting to the computer? Is there any external device for OTA? or can I use 1 CYBT-343026-01 as a host device to flash all other modules?
How can I do this please help me.
Thanks in advance
Neeraj
AnjanaM_61
First comment on KBA 5 questions asked First question asked
Hi NeDh_4602711 ,
For first time programming, you should use HCI UART interface only. And in that you can enable OTA upgrade option, so that for second time, you can use OTA for FW upgrade.
For OTA FW upgrade details, please go through the example /20706-A2_Bluetooth/apps/snip/ota_firmware_upgrade as well as the document /20706-A2_Bluetooth/doc/WICED-Firmware-Upgrade-Library.pdf
Peer apps for OTA is also available in SDK itself : /20706-A2_Bluetooth/apps/snip/ota_firmware_upgrade/peer_apps
Thanks & Regards,
Anjana
AnjanaM_61
Hi NeDh_4602711 ,
Thanks & Regards,
Anjana
