Greetings,
I'm having some trouble with the CYBT-343026-EVAL evaluation board and the WICED Studio 6.0 SDK.
After having installed all the drivers of the board (USB Serial Dual Channel drivers included) I have referred to KBA221025 as stated in the user guide and followed the steps mentioned there:
     1.- Download CYBT_343026_EVAL_PLATFORM_FILES.zip attached with this KBA.
     2.- Save and extract the downloaded file in your computer.
     3.- Navigate to CYT_343026_EVAL_PLATFORM_FILES > CYBT_343026_EVAL and copy this folder.
     4.- Paste the folder in WICED Studio 5.1 folder path …\ WICED-Studio-5.1\20706-A2_Bluetooth\Platforms\. Figure 1 shows the location of folder in the WICED Studio 5.1.
Now, although in the Project Explorer I can see that the folder has been added, there are only example build targets for the CYW920706WCDEVAL board in the Make Target tab.
I figure I can't use the CYW920706WCDEVAL board's demos with my CYBT-343026-EVAL board since I get a device detection failure message saying that the CYW20706 was not detected.
From the KBA221025 I understood that I should be able to see a sample make target called "demo.hello_sensor-CYBT_343026_EVAL download" in the Make Target tab.
Is there any step that I am missing?
Thank you in advance.
Best regards.
The make target will be not be added automatically. You will have to manually create a new make target:
"demo.hello_sensor-CYBT_343026_EVAL download".
To do so, you can right-click on the 20706-A2_Bluetooth folder in the Make Target window and click 'New'.
Yes, that was the step I was missing.
Thank you very much for your response yssu​.
Regards.
