Hi all:
Now I use the MeshLighting which is supported by cypress to give the device remote firmware upgrade .
the OTA interface is below:
the Firmware file is XXX-CYW920735Q60EVB_01-rom-ram-Wiced-release.ota.bin
but I don't know what is the metadata file
there are some selections for example proxy DFU to all , proxy DFU to device, app DFU to all , app DFU to device
I don't know the difference between them during OTA!
thanks!
mandy
- cyw20735
Sample metadata file is attached in my previous post. Please check it.
Short description of the options are as below.
Proxy DFU to all: Provisioner updates the firmware for the proxy device, and the proxy device will distribute and updates the firmware to all the other nodes.
Proxy DFU to device: Provisioner updates the firmware for the proxy device, and the proxy device will distribute and updates the firmware to a selected node.
App DFU to all: Provisioner directly updates the firmware for all the nodes.
App DFU to device: Provisioner directly updates the firmware for a selected node.
-Dheeraj
